Старый 09.09.2021, 16:11   #1
d365technext: D365FO Interview Question
Источник: https://d365technext.blogspot.com/20...wQuestion.html
D365FO Interview Questions & Answers
What is Microsoft Dynamics AX?
Answer: Link
Difference Between Edit And Display Method?
Answer: Link
What Is An Index?
Answer: Link
Question-1 : How to create an X++ job/Runnable Class in D365 for Financial & Operations?
Answer: Follow the steps given in the link here.
Question-2 : What is the development environment used in D365FO?
Answer: Visual Studio IDE
Question-3 : Rich client is utilized in D365FO ? True or False?
Answer: False
Question-4 : What is ConView() ?
Answer: It is a Global class that can be utilized to view elements in a tree format.
Question-5: How to update the cross-reference tool?
Question-6: How do we utilize Unit Test Framework in AX?
Question-7: What is the keyword used in X++ to access multiple companies?
Answer: Crosscompany
Question-8: Why is that we prefer TempDB over InMemory tables while using them in queries for reports?
Answer: Despite both being temporary type tables, TempDB tables can be used in Joins
Question-9: Where can we view all the AOT elements in Visual Studio IDE for D365FO?
Answer: Visual Studio IDE > View > Application Explorer
Question-10: How to create a simple dialog using class – AX 2009?
Answer: X++ Code available here.
Question-11: What is the purpose/use of Delta Schema Update in the DMT tool in AX 2009?
Answer: Click here
Question-12: How to create a model in D365FO?
Answer: Click here
Question-13: How to change a model for a project in D365FO?
Answer: Click here
Question-14: How to create Data Entities in D365FO?
Answer: Click here
Старый 10.09.2021, 02:26   #2
trud is offline
trud
1,039 / 1635 (57) ++++++++
Which development environment is used in D365FO?
Answer: Visual Studio IDE.
Это как в анекдоте
Во валит, гад!
Старый 10.09.2021, 10:52   #3
Pandasama is offline
Pandasama
467 / 140 (5) +++++
почему-то текст поста по ссылке не совпадает с форумным - там про 2009 ничего нет, например
d365technext: Bar Code in SSRS Report D365FO Blog bot DAX Blogs 1 21.09.2021 21:54
d365technext: Create Vendor using X++ D365FO & AX-2012 Blog bot DAX Blogs 0 03.09.2018 21:12
d365technext: Environment hot fixes D365FO Blog bot DAX Blogs 0 16.08.2018 14:11
d365technext: SSRS Report with custom fonts in D365FO Blog bot DAX Blogs 0 15.08.2018 17:15
Часовой пояс GMT +3, время: 10:36.
