Старый 03.05.2021, 16:11   #1
ax.docentric: Comment on Import/Export Container Data Fields Using D365FO Data Management by Sanja Kolundžija
Источник: https://ax.docentric.com/import-expo.../#comment-2484
In reply to Guillaume De Bue.Hi Guillaume,PrintMgmtSettings.PrintJobSettings field is a container that we need to transform into an unmapped string field for the export purpose. The only way to populate an unmapped field during export is in the postLoad() method, so we didn’t have much choice there.It is true, as you pointed out, that postLoad() requires staging (it can’t be skipped in this case) and for sure influences the performance. I think that it all depends on the use-case. Our example is based on the Docentric Print Management settings data entity, where companies usually don’t have large amount of data, and on the other hand don’t have any OOTB way of migrating the settings among different environments.Kind regards,Sanja
ax.docentric: Comment on Import/Export Container Data Fields Using D365FO Data Management by Guillaume De Bue Blog bot DAX Blogs 0 30.04.2021 14:13
ax.docentric: Comment on Check execution in batch in Print management in D365FO by Miha Vuk Blog bot DAX Blogs 1 22.12.2020 18:14
ax.docentric: Comment on Create a new custom report in D365FO using Docentric by Ana Blog bot DAX Blogs 1 10.11.2020 19:11
dennis365foroperations: Yes, it’s here! The Copy configurations feature (and a look at other improvements related to Data Management) Blog bot DAX Blogs 0 12.10.2017 16:11
dynamics-coe: Dynamics AX Export/Import Framework for Vendor balance migration Blog bot DAX Blogs 0 22.05.2013 20:13
Часовой пояс GMT +3, время: 09:27.
