Старый 22.03.2021, 03:57   #1
ax.docentric: Comment on Configure SharePoint Online integration in D365FO OneBox by Nguyễn Thành Được
Источник: https://ax.docentric.com/configure-s.../#comment-2158
Hi admin,I tried to To add the created certificate to the Microsoft Dynamics ERP application on Azure, follow the 8 steps outlined in the beginning of the Enable authentication with the S2S certificate from OneBox in AAD chapter. But Power Shell show errror at line "Connect -MsolService". I make sure that the MSOnline module is already installed in the Windows PowerShell.Error in Power Shell.Connect : The term 'Connect' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the spelling of the name, or if a path was included, verify that the path is correct and try again.At line:2 char:1+ Connect -MsolService+ ~~~~~~~+ CategoryInfo : ObjectNotFound: (Connect:String) [], CommandNotFoundException+ FullyQualifiedErrorId : CommandNotFoundExceptionPlease give me an advise.Thank you so much
ax.docentric: Comment on Check execution in batch in Print management in D365FO by Miha Vuk Blog bot DAX Blogs 1 22.12.2020 18:14
emeadaxsupport: AX Performance - Analyzing key SQL Server configuration and database settings Blog bot DAX Blogs 0 28.09.2015 14:11
Microsoft Dynamics CRM Team Blog: Impact of Dynamics CRM December 2012 Service Update and SharePoint Online Service Update on CRM-SharePoint Integration Blog bot Dynamics CRM: Blogs 0 09.01.2013 01:11
Часовой пояс GMT +3, время: 09:59.
