Старый 01.03.2021, 00:19   #1
daxmusings: Use The New Packaging in the Legacy Build Pipeline
Источник: http://feedproxy.google.com/~r/Dynam...-pipeline.html
The legacy pipeline from the build VM has its own PowerShell script that generates the packages. However, it always puts the F&O platform version into the package file name which can make it more difficult to use release pipelines or including ISV licenses into your packages since the version number changes with each update, requiring you to update your pipeline settings (and finding out the actual build number to use). Continue reading below or watch the YouTube video to learn how to swap the packaging step from the legacy pipeline with the Azure DevOps task which lets you specify your own name for the deployable package zip file. You can find the official documentation on the packaging step here.
Read more...
daxmusings: Updating The Legacy Pipeline for Visual Studio 2017 Blog bot DAX Blogs 0 25.01.2021 22:16
Rahul Sharma: Create Build Server, DevOps Branch, Pipeline for Dynamics 365 Finance and Operations Blog bot DAX Blogs 0 21.06.2020 16:13
daxmusings: Repost: Pointing Build Definitions to Specific VMs (agents) Blog bot DAX Blogs 0 25.03.2019 20:12
daxmusings: Pointing Your New Build Definition to a Different Branch Blog bot DAX Blogs 0 14.09.2017 13:11
daxmusings: Pointing Your New Build Definition to a Different Branch Blog bot DAX Blogs 0 03.11.2016 03:34
Часовой пояс GMT +3, время: 23:29.
