Старый 25.01.2021, 22:16   #1
msdynamicsworld: From the Microsoft Dynamics AX/365 Finance and Operations Blogs: AX integration; Dual write; New feature; D365FO performance
Источник: https://msdynamicsworld.com/story/mi...te-new-feature
This week on the Dynamics AX and Dynamics 365 Finance and Operations blog roundup:
  • How to integrate Dynamics AX 2012 with Azure and Power Platform
  • Application of dual write: ticketing system for Dynamics 365 Finance and Operations
  • New feature: enable batch processing for bank payment advice reports
  • D365FO performance: Periodic import of one million ledger journal lines
On Sertan's dev.blog on Dynamics AX, Tayfun Sertan Yaman wrote that Dynamics 365 Finance and Operations offers many ways to directly integrate with Azure and the Power Platform. As for Dynamics AX 2012 – not so much.
In his post, Yaman described some of the possible options to integrate AX 2012 on-premises with Azure and the Power Platform and discussed when and how to use them.
Those options include built-in AX 2012 and Azure integration solutions as well as options for read-only integrations, read-write integrations, and more advanced options.
<h2>Application of dual write: Ticketing system for Dynamics 365 Finance and Operations
Старый 26.01.2021, 10:16   #2
Vadik is offline
Vadik
Аватар для Vadik
3,631 / 1853 (69) ++++++++
Trunin offered some steps to enable you to run a D365FO performance test. Because it will be for a standard demo database, it won't be hard to execute it, he stated.
In his post Trunin described the test, explained the preparation and setup, and then provided the results of the test
Это про блог trud, если что
-ТСЯ или -ТЬСЯ ?
Последний раз редактировалось Vadik; 26.01.2021 в 14:58.
msdynamicsworld: From the Microsoft Dynamics 365 for Finance and Operations/AX Blogs: Upgrade; Role assignment; Budgeting basics; D365 Finance and Supply Chain Management Blog bot DAX Blogs 0 30.11.2019 05:35
msdynamicsworld: From the Microsoft Dynamics 365 for Finance and Operations/AX Blogs: Rule offset; Demo users; Cycle count; Electronic reporting Blog bot DAX Blogs 0 30.08.2019 21:20
msdynamicsworld: From the Microsoft Dynamics 365 for Finance and Operations/AX Blogs: Performance Review; Containerization; Entity export; Async method (http://axforum.info/story/microsoft-dynamics-365-finance-and-operationsax-blogs-performance-revie Blog bot DAX Blogs 0 24.08.2019 00:22
Часовой пояс GMT +3, время: 05:13.
