Старый 07.05.2020, 04:24   #1
If you do not see your new Number sequence in Segments
Источник: http://alexvoy.blogspot.com/2020/05/...ew-number.html
[COLOR=rgba(0, 0, 0, 0.9)]You created a new number sequence, say BNR close - extension, for example, as decribed here . But neither does it appear in Segment configuration form nor in the list of Generate Wizard.[/COLOR]
[/COLOR]
[COLOR=rgba(0, 0, 0, 0.9)]To overcome this issue, you can simply reset number sequences by the following menu item.[/COLOR]
[COLOR=rgba(0, 0, 0, 0.9)]Go to Organization administration > Number sequences > Number sequences.[/COLOR]
[/COLOR]
[COLOR=rgba(0, 0, 0, 0.9)][/COLOR]
Then it appears in Segment configuration.
[/COLOR]
[COLOR=rgba(0, 0, 0, 0.9)]Now you can generate your new number sequence in Wizard.
[/COLOR]
dynamicsaxse: November 2018 Release – Dynamics AX2012 R3 update Blog bot DAX Blogs 0 15.11.2018 09:11
emeadaxsupport: Number sequence XXXX has been exceeded Blog bot DAX Blogs 0 29.04.2014 20:11
goshoom: Year in number sequence (AX2012) Blog bot DAX Blogs 0 16.10.2013 16:11
Часовой пояс GMT +3, время: 10:26.
