Старый 14.06.2019, 22:20   #1
How to enable a few fields on a form data source
Источник: http://alexvoy.blogspot.com/2019/06/...form-data.html
<div dir="ltr" style="text-align: left;" trbidi="on"><div style="background: #ffffff; overflow:auto;width:auto;border:solid gray;border-width:.1em .1em .1em .8em;padding:.2em .6em;">///
/// Helper for form data source functionality
class FormDataSourceHelper
/// Allow edit for given fields only; the rest is non-editable
/// Caller form data source
/// Container with fields numbers for allowing
public static client void allowEditFields(FormDataSource _fds, container _fields)
DictTable dictTable;
int fieldCnt, fieldNumber;
Set fieldsSet;
if(!_fds)
throw Error(Error::wrongUseOfFunction(funcName()));
dictTable = new DictTable(_fds.table());
if(!dictTable)
// everything is fine if we are here already
// first convert a given container of fields numbers to a set of unique values
fieldsSet = new Set(Types::Integer);
for(fieldCnt = 1 ; fieldCnt
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
NAV Team: How to: Enable Import/Export of Bank or Payroll Files Using the Data Exchange Framework Blog bot Dynamics CRM: Blogs 0 18.10.2013 02:33
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
dynamicsaxtraining: Purchase Blog bot DAX Blogs 0 11.03.2012 05:25
Часовой пояс GMT +3, время: 03:18.
