Старый 11.03.2019, 11:11   #1
axforum blogs: Excel Add-In - Update Ledger journals
Источник: //axforum.info/forums/blog.php?b=8265
To enable update on LedgerGeneralJournalService perform the following steps:
Add RecId field to the LedgerJournalTrans datasource of the AxdLedgerGeneralJournal query.
Set Update property of both LedgerJournalTable and LedgerJournalTrans datasources of the AxdLedgerGeneralJournal query to Yes.
Set Validate Property of the CustEPRemitInfo_BR relation of the LedgerJournalTrans table to No.
Implement bypass to super of update and updateList methods of the AxdLedgerGeneralJournal class.
Implement update method on the LedgerGeneralJournalService class
Add update method on the LedgerGeneralJournalService service and perform Register service on the service.
Deploy LedgerServices service group.
Open Organization administration \ Setup \ Document management \ Document data sources form and make sure LedgerGeneralJournalService is activated
Миниатюры
alexef: Клиент-банк функционал, NAV 2013 R2 (RU), пример с картинками Blog bot Dynamics CRM: Blogs 2 07.12.2014 21:51
emeadaxsupport: Connecting Retail Components on an External Computer to the Microsoft Dynamics AX R3 Azure Lifecycle Services Demo Virtual Machine Blog bot DAX Blogs 0 28.06.2014 00:13
emeadaxsupport: Importing a Budget via the Excel Add-in Blog bot DAX Blogs 0 10.09.2012 23:15
german_nav_developer: “Wutschen und Wedeln”: Sortieren und Filtern in Dynamics NAV - Unterschiede zwischen SQL Server und Native Blog bot Dynamics CRM: Blogs 0 20.05.2011 21:06
Nav developer: Overview of NAV blogs in 2008 Blog bot Dynamics CRM: Blogs 0 07.12.2008 02:18
Часовой пояс GMT +3, время: 23:50.
