Старый 10.03.2019, 17:19   #1
axatoz: D365 – Data Entity Method Call Sequence
Источник: https://axatoz.wordpress.com/2019/03...tity-sequence/
Thanks to Uwe Kruger for sharing this. I keep it here for my own reference.
My notes:
  1. The postLoad method is called also by import! Since postLoad is the recommended place to set values for the virtual fields, this potentially slow-down the import process unnecessarily.
  2. Be careful by using the postTargetProcess method! This method is called at the end of EACH thread/task-bundle if you are using the “Import threshold record count” option.
  3. Previously, you could add postTargetProcess only to a newly created entity, but now you can extend any entity using CoC
Extension is simple.
[ExtensionOf(tableStr(DataEntity))]
final public class DataEntity_Extension
    public static void postTargetProcess(DMFDefinitionGroupExecution _dmfDefinitionGroupExecution)
        // Do no call next
        //logic here
[COLOR=var(--color-neutral-600)]Please note that this can be done only MDM scenarios but not via ODATA because ODATA updates, inserts records row by row and there is no post event\method to use. You might wish to use OData action to perform post actions on records.[/COLOR]
atinkerersnotebook: Configuring a BYODB and Creating a Full and Incremental Entity Export Blog bot DAX Blogs 0 25.05.2018 15:11
mohsinkhalid: #D365 Solution: The property ‘ComputedFieldMethod’ must be set with the name of a valid data entity method if ‘IsComputedField’ is set to ‘Yes’. Blog bot DAX Blogs 0 21.03.2018 21:11
dennis365foroperations: Yes, it’s here! The Copy configurations feature (and a look at other improvements related to Data Management) Blog bot DAX Blogs 0 12.10.2017 16:11
stoneridgesoftware: Automated Data Entity Import Using DIXF in Dynamics AX Blog bot DAX Blogs 0 07.08.2017 20:19
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
Часовой пояс GMT +3, время: 21:19.
