#1 |
axaptacorner: How to read excel and update record in AX2012 through X++ code
Источник: http://axaptacorner.blogspot.com/201...record-in.html
============== static void POCUpdatePurchaseDetails_JS(Args _args) { SysExcelApplication application; SysExcelWorkbooks workbooks; SysExcelWorkbook workbook; SysExcelWorksheets worksheets; SysExcelWorksheet worksheet; SysExcelCells cells; COMVariantType type; Dialog dialog = new Dialog("Excel upload utility"); dialogField dialogFilename; int row; int totalUpdatedRecord = 0; FileName filename; InventTable inventTable; ItemId itemId; ItemGroup itemGroup; InventTableModule inventTableModule; ; application = SysExcelApplication::construct(); workbooks = application.workbooks(); dialogFilename = dialog.addField(extendedTypeStr(FilenameOpen),"@SYS53125"); dialog.filenameLookupTitle("Update data from excel file"); dialog.filenameLookupFilter(["@SYS28576",'*XLSX', "@SYS28576",'*XLS']); if (!dialog.run()) return; filename = dialogFilename.value(); try { workbooks.open(filename); } catch (Exception::Error) { throw error("File cannot be opened."); } workbook = workbooks.item(1); worksheets = workbook.worksheets(); worksheet = worksheets.itemFromNum(1); cells = worksheet.cells(); row=1; do { row++; itemId = cells.item(row, 1).value().bStr(); ttsbegin; inventTable = InventTable::find(itemId,true); inventTableModule=InventTableModule::find(inventTable.ItemId,ModuleInventPurchSales::Purch,true); if (inventTable) { inventTableModule.Price=str2num(cells.item(row, 2).value().bStr()); inventTableModule.PriceUnit=str2num(cells.item(row, 3).value().bStr()); inventTableModule.update(); totalUpdatedRecord++; } ttscommit; type = cells.item(row+1, 1).value().variantType(); } while (type != COMVariantType::VT_EMPTY); application.quit(); info(strFmt('Data updated, total record=%1 record',totalUpdatedRecord)); } Источник: http://axaptacorner.blogspot.com/201...record-in.html
