Старый 01.12.2018, 03:13   #1
stoneridgesoftware: Best Practices for Windows Patching in Dynamics AX 2012 or Previous Versions
Источник: https://stoneridgesoftware.com/best-...ious-versions/
If you are planning to do some Windows patching for Dynamics AX 2012 (or lower versions) read through the following recommendations before beginning your project.
Tips to consider for Windows Patching Dynamics AX 2012:
• For Dynamics AX, please inform users the system would be down for maintenance. Have users reschedule the Dynamics AX batch jobs so they get run before the system goes down or after the AX system comes back up. They may set the job status to Withhold or change the next run time to a time after the Windows patches are done.
• Take a full SQL backup of all your SQL databases.
• Make sure no users are in the Dynamics AX system before you shutdown AX (AOS). Coordinate this with any other 3rd parties AX integration you may have.
• Shut down all the services related to Dynamics AX, AND set the services Startup type to Manual – during the windows patching, your servers might reboot multiple times. So, you want to make sure services related to AX are set to manual so they don’t get started automatically during the patching.
• The services to be shut down for Dynamics AX:
–   SQL, SSRS, SSAS, AOS(S), Sharepoint, Management reporter, Atlas, and any other 3rd party products you may have integrated with AX ( shut it down in this order, and start them back up in this order as well after the patching is done).
• Always patch your lower Dynamics AX environments first (Development, TEST, UAT ie. Non-Production)– to make sure the patches are not going to cause any issues.
• Patch all servers related to that Dynamics AX environment at the same time. Do not apply patches to only some of your AX servers in your AX environment. (SQL, SSRS, SSAS, SharePoint, AOS, RDP servers ie. any servers with AX component or 3rd party installed)
If you have further questions or need help with your system, let us know!
emeadaxsupport: AX Performance Troubleshooting Checklist Part 2 Blog bot DAX Blogs 0 09.09.2014 16:11
DAX: Microsoft Dynamics AX 2012 R3 is now available! Blog bot DAX Blogs 1 02.05.2014 23:00
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics NAV 2009 SP1 Blog bot Dynamics CRM: Blogs 0 11.06.2010 16:33
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics NAV 2009 Blog bot Dynamics CRM: Blogs 0 04.06.2010 13:21
Часовой пояс GMT +3, время: 17:14.
