Старый 28.11.2018, 03:42   #1
lcs: Issues when syncing to BPM using a custom Azure DevOps (VSTS) process template
Источник: https://blogs.msdn.microsoft.com/lcs...cess-template/
When setting up your Azure DevOps (VSTS) project in Lifecycle Services (LCS), if you use an inherited process template with custom fields, you may receive the following warning message: "The selected VSTS project is based on a custom process template. Custom process templates are not supported and may cause errors when synchronizing Business Process Modeler...
lcs: Visual Studio Team Services has been rebranded to Azure DevOps Blog bot DAX Blogs 0 13.09.2018 05:29
lcs: Business process modeler (BPM) experience in LCS Blog bot DAX Blogs 0 02.02.2017 07:15
axsa: Updates to Business process management tools on Lifecycle services LCS Blog bot DAX Blogs 0 27.06.2014 03:39
Microsoft Dynamics CRM Team Blog: Using the Business Process Flow Designer Blog bot Dynamics CRM: Blogs 0 24.10.2013 05:13
Часовой пояс GMT +3, время: 13:29.
