Старый 18.10.2018, 13:11   #1
daxrunbase: Synchronize Models between workspaces in MSDyn365FO
Источник: https://www.daxrunbase.com/2018/10/1...in-msdyn365fo/
For our upgrade project we have decided to create 4 packages/models to start with, which is enough to separate larger areas. Once the models have been created on my VM, I had to make it available for everyone. The goal was to synchronize models between workspaces of other developers. Package / Model Description JAD Core Core application framework changes, essentially...
The post Synchronize Models between workspaces in MSDyn365FO appeared first on DAXRunBase.
daxrunbase: Developer VM performance for MSDyn365FO Blog bot DAX Blogs 5 17.10.2018 10:50
axdaily: Models in AX 2012 Blog bot DAX Blogs 0 28.04.2011 04:27
mfp: AX models - Part 4 - Working with models inside MorphX Blog bot DAX Blogs 4 26.11.2009 16:55
mfp: Introducing AX models - Part 3 Blog bot DAX Blogs 0 16.10.2009 16:05
Часовой пояс GMT +3, время: 04:34.
