Go Back   AXForum > Microsoft Dynamics AX > DAX Blogs
Forgotten Your Password?
Register Forum Rules FAQ Members List Today's Posts Search
Thread Tools Search this Thread Display Modes
Prev Previous Post   Next Post Next
Old 22.09.2018, 08:24   #1
ievgensaxblog: MSDyn365FO. How-to pass generic types to .Net method
Источник: https://ievgensaxblog.wordpress.com/...to-net-method/
There is a wonderful blog post about Generic types in X++. And as It says, the easiest way to work with generic types in X++ is to create .Net library and expose non-generic interface, because X++ compiler has lots of limitations.
However, if you really want to have some fun and stick to X++, it’s possible with a help of reflection.
Let’s say we have a C# class that accepts  List and we want to invoke it from X++:
public class Class1{ public static string myMethod(List list) { string res = string.Empty; foreach (var array in list) { foreach (string s in array) { res += s; } }return res; }}We cannot simply declare:
var stringList = new System.Collections.Generic.List();
Looks like X++ parser cannot handle “
Similar Threads
Thread Thread Starter Forum Replies Last Post
ievgensaxblog: D365FOE. How to override form data source field lookup method. Blog bot DAX Blogs 0 10.01.2018 05:11
goshoom: Generic types in X++ (AX 7) Blog bot DAX Blogs 0 10.04.2017 13:11
Navigate Into Success: Try..Catch for .NET Interoperability Blog bot Dynamics CRM: Blogs 0 29.10.2014 09:00
fed: Net requirements update in MRP Module and Working Set of MRP Blog bot DAX Blogs 14 08.05.2012 13:09
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2025, Jelsoft Enterprises Ltd.
Contacts E-mail, Advertising.
