Старый 04.09.2018, 15:11   #1
d365technext: Number Sequence D365FO
Источник: http://d365technext.blogspot.com/201...ce-d365fo.html
Number sequences are used to generate readable, unique identifiers for master data records and transaction records that require identifiers.
In this demo, I am going to create a new number sequence for customer group form.
Create a new class with name NumberSeqModuleCustomer_CustGroup that extends the NumberSeqModuleCustomerclass and then create the method loadNumberSequence.
Reference Screenshot:
Now create extension class of CustParameters_Extension and add your custom method to find number sequence..
Now create Run able class to initialize the number sequence...
Perform build & Sync and load the number sequence. In my demo i have place Action menu item of executable class on following navigation.
Now Navigate to organization administration > Number sequence and generate number sequence.
Next Step to Navigate to Account receivable parameter setup to veriy our newly create number sequence loaded successfully or not... You have to verify on your desire number sequence module.
Next step to override CustGroup form data source Initial value event.
Perform build & Sync and verify on your cust group.. for me its working fine please have look on below screenshot.
Please feel free to contact me if you are facing any issue during implementation of above blog.
emeadaxsupport: AX for Retail: Size Barcode setup and creation with number sequence Blog bot DAX Blogs 0 12.02.2015 01:12
emeadaxsupport: Number sequence XXXX has been exceeded Blog bot DAX Blogs 0 29.04.2014 20:11
goshoom: Year in number sequence (AX2012) Blog bot DAX Blogs 0 16.10.2013 16:11
emeadaxsupport: Where is the System ID number sequence used? Will it run out? Blog bot DAX Blogs 0 25.05.2011 00:11
emeadaxsupport: How to set the number sequence for Global Address Book when virtual companies are used Blog bot DAX Blogs 0 24.08.2009 14:05
Часовой пояс GMT +3, время: 02:54.
