Старый 31.08.2018, 16:11   #1
cleverax: WHS: License plate grouping policy
Источник: https://cleverax.wordpress.com/2018/...ouping-policy/
Purchase, Transfer and Load receiving mobile device menu items have one parameter that makes a difference to the creation of a license plate and put away work. This parameter is called “License plate grouping policy” and it has 3 options: None, License plate grouping and User defined. In this post we will review the difference … Continue reading WHS: License plate grouping policy →
organicax: WMS Mobile device menu – License plate build Blog bot DAX Blogs 0 01.09.2016 01:18
DynamicsAxSCM: Change license plate, split quantity, skip and override location during inbound put away Blog bot DAX Blogs 0 27.11.2015 16:11
axmfg: Order picking from license plate locations Blog bot DAX Blogs 0 23.09.2015 17:11
Dynamics AX Sustained Engineering: KB3030212 Duplicate InventDim records are created which cause errors in the WHS if license plate IDs include trailing blanks Blog bot DAX Blogs 0 22.01.2015 20:12
DynamicsAxSCM: Receiving a pallet with mixed items based on a packing structure using License plate receiving mobile device menu item Blog bot DAX Blogs 0 18.09.2014 22:12
Часовой пояс GMT +3, время: 03:16.
