Старый 29.08.2018, 20:16   #1
d365technext: Map Enumerator VS Map Iterator
Источник: http://d365technext.blogspot.com/201...-iterator.html
Map Enumerator
Map enumerators are automatically created on the same tier as the map when you call the Map.getEnumerator method.
Using the MapEnumerator class avoids a potential problem in code marked as Called from, where the iterator and map can end up on separate tiers
Map enumerators require less code than map iterators, they perform slightly better.
Map Iterator
Map Iterator should be used when you want to delete items from a list by using the MapIterator.delete method.
Классы коллекций (инициализация, сериализация): List, Set, Map. petergunn DAX: База знаний и проекты 14 09.07.2025 11:37
Не корректная сортировка в Map-e и Set-е. AX2009 RU5 Pustik DAX: Программирование 12 03.05.2016 21:28
Microsoft Dynamics CRM Team Blog: Creating Heat Maps with Bing Maps and Dynamics CRM Blog bot Dynamics CRM: Blogs 0 31.10.2012 03:16
CRM DE LA CREME! Editing the CRM Site Map made so easy!!!!... Blog bot Dynamics CRM: Blogs 1 14.02.2010 11:46
Dynamics AX: Map Object Sorting - a real issue Blog bot DAX Blogs 7 15.10.2008 12:02
Часовой пояс GMT +3, время: 04:12.
