Старый 08.08.2018, 21:12   #1
d365technext: Vendor Aging Report D365FO
Источник: http://d365technext.blogspot.com/201...rt-d365fo.html
As we all knows customization in Vendor Aging report or Customer Aging report is nightmare..
The same thing i faced in previous week. when a task assigned to me to debug the vendAging Report..
Report elements
I have done some research in two days on this and found the below information:
1) Using CustVendTable Map and VendTable Query : Inserting data into CustVendTransAging Table.
(Referà Class : VendBalanceList :: calculateDetailsForMultiple ->> CustVendAgingCalculation à process method à insertCustVendData() method.
2) Inserting data into CustVendAgingProcessingTmp table using VendTransand VendSettlement Tables.
( Refer à Class : CustVendAgingCalculation àselectTransactions() à selectOpenTransactions() and selectClosedTransactions() methods .
3) Inserting data into CustVendAgingProcessingDetailsTmp fromCustVendAgingProcessingTmp Table
( Refer à Class : CustVendAgingCalculation à selectDetailsOfTransactions()
4) Inserting data into CustVendAgingCalculatedTmpusing CustVendAgingProcessingTmp Table and CustVendAgingProcessingDetailsTmp Tables.
( Refer : Class : CustVendAgingCalculation:Process method).
5) Inserting data into VendTmpAccountSum Table usingCustVendAgingCalculatedTmp.
(Refer : Class ::VendBalanceList:insertIntoTmpAccountSum())
6) Inserting data into VendAgingReportTmp Table (which is the main temporary table used for populating data in the report) using VendTmpAccountSumandCustVendTransAging tables.(VendAgingDP class)
I would request you to debug and check the classes above and tables and that would help you get more information.
NAV Team: Report Execution Insights Blog bot Dynamics CRM: Blogs 0 30.10.2014 15:02
ax-erp: Walkthrough: Creating a Report Bound to a Report Data Provider Class (X++ Business Logic) [AX 2012] Blog bot DAX Blogs 0 20.09.2012 11:11
Nav developer: NAV 2009 - Report Designer - Introduction to the new environment Blog bot Dynamics CRM: Blogs 0 15.11.2008 20:21
Часовой пояс GMT +3, время: 13:32.
