Старый 30.04.2018, 17:12   #1
palleagermark: Why you can't setup sharing of customers and vendors in 8.0
Источник: http://www.agermark.com/2018/04/why-...customers.html
The release notes for 8.0 says that you can now share customers and vendors with the data sharing feature. But it also says: "To enable this functionality, contact your Solution Architect, who will verify that your business requirements and data volumes will be acceptable for data sharing, and then enable the sharing policies in your environment".
So what does that mean?
Microsoft has started using a "flighting" concept where they add features on a release, but keep them turned of until activated for the tenant by Microsoft. This is something you can see Microsoft check in their code.
A new isFlightEnabled method on the Global class does the work of checking if a feature is enabled or not.
If you want to cheat a bit, you could probably add an event handler to this method and return true for the feature you want to enable. I haven't tried that though.
In class SysDataSharingValidation, method validateTableCanBeSharedWithPolicy, you can see an example of how this is called:
emeadaxsupport: Trade Allowance Management Blog Series - Setup Blog bot DAX Blogs 0 01.05.2015 01:12
atinkerersnotebook: Letting Customers and Vendors Manage Themselves by Using Self-Service Portals within Dynamics AX Blog bot DAX Blogs 0 14.01.2015 19:11
atinkerersnotebook: Use Print Management to automatically email documents to customers & vendors Blog bot DAX Blogs 0 08.12.2013 18:11
atinkerersnotebook: Using Excel to Import Customers and Vendors in Dynamics AX 2012 Blog bot DAX Blogs 0 19.07.2013 15:11
dynamicscare: Using Excel to Import Customers and Vendors in Dynamics AX 2012 Blog bot DAX Blogs 0 05.07.2013 19:12
Часовой пояс GMT +3, время: 01:54.
