Вернуться   AXForum > Microsoft Dynamics NAV > NAV: Blogs
Старый 08.03.2018, 19:16   #1
saurav-nav: AL - Installing AL with Microsoft Dynamics NAV.
Источник: https://saurav-nav.blogspot.com/2018...microsoft.html
Hi all,
With this as the first article, i will start my journey towards AL (future for Dynamics NAV). I know its late but due to some personal commitments, i was unable to start it early.
In this article, we will configure AL environment on Local Environment. If you already have configured then please provide what I missed while trying to find it.
Step 1 - Add Mordern Developer environment.
If you have not installed NAV 2018 then make sure to select Modern Development Environment during installation.
If you have already installed then Run setup again and select add or remove the component and select Modern Development Environment.
Step 2 - Download and install Visual Studio Code.
Download the latest Visual Studio Code using the link.
Install the Visual Studio Code as shown below. (Run as administrator)
Step 3 - Install Extensions.
Open Visual Studio Code, and then select Extensions menu (Left-hand Last option).
Search for Install.VSIX.
Select and install the Extension as shown below.
After Installation of extension then from the file menu, select the Open folder, and Select Modern Dev Environment folder.
** Default Path - C:\Program Files (x86)\Microsoft Dynamics NAV\110\Modern Development Environment
Select the ALLanguage.vsix, Right click, and select install Extension.
You also may run into error message, as i did during installation (shown below).
Manually write code to install the extension -> code --install-extension ALLanguage.vsix
AL Language is Extension is installed and in next article how we refer NAV C/AL Objects into VS.
Let me know your views on same and if you have any issues.
Regards,
Saurav Dhyani
saurav-nav.blogspot.in
За это сообщение автора поблагодарили: Sancho (1).
saurav-nav: Microsoft Dynamics NAV 2018 - Changes in Service Tier. Blog bot NAV: Blogs 0 11.01.2018 15:11
sp-nav-tech: Navision 2009 R2 installation on production environment Blog bot NAV: Blogs 0 16.08.2017 17:11
NAV Team: Best Practices Tips and Tricks for Upgrading to Dynamics NAV 2013 R2 or Dynamics NAV 2015 Part 2 Blog bot Dynamics CRM: Blogs 0 17.06.2015 11:00
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2013 Update Rollup 2 Blog bot Dynamics CRM: Blogs 0 15.04.2014 01:15
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 13 Blog bot Dynamics CRM: Blogs 0 27.03.2013 22:12
Часовой пояс GMT +3, время: 06:44.
