Старый 17.08.2017, 18:11   #1
Afna CRM: Executing SQL queries in CRM database on behalf of another user
Источник: http://a-crm.blogspot.com/2017/08/ex...-database.html
If you are using filtered views in SSMS it is not possible to see what data will be returned for other users. But there is a way!
The GUID of the user is stored in the SQL CONTEXT_INFO. All you have to do is to run this piece of code:
DECLARE @binUserGuid VARBINARY(128)
DECLARE @userGuid UNIQUEIDENTIFIER
SET @userGuid =''
SET @binUserGuid =CAST(@userGuid ASVARBINARY(128))
SETCONTEXT_INFO @binUserGuid
From now on you will be able to query the data as if you would be logged in as another user.
To clear the context info simply execute
SETCONTEXT_INFO 0x
I hope this helps those who are testing SQL queries for the CRM reports.
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 8 Blog bot Dynamics CRM: Blogs 1 30.04.2016 10:26
gustafwesterlund: 10 Tips for Success designing solutions for Dynamics CRM Blog bot Dynamics CRM: Blogs 0 03.12.2015 17:11
Microsoft Dynamics CRM Team Blog: Upgrading to the CRM 2013 User Experience Blog bot Dynamics CRM: Blogs 0 31.10.2013 06:12
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 11 Blog bot Dynamics CRM: Blogs 0 06.10.2012 05:27
crminthefield: Restoring a CRM database from SQL Enterprise to Standard Blog bot Dynamics CRM: Blogs 0 27.06.2011 21:11
Часовой пояс GMT +3, время: 01:47.
