Старый 09.08.2017, 05:17   #1
organicax: Setting up a product image for a released item
Источник: https://organicax.com/2017/08/08/set...released-item/
If you want to setup a basic product image for a released item then you can do that from the fact box on the released item. It’s worth noting that the images are stored based on how the document handling is setup. So you might want to consider this to manage storage size/location.
It’s also worth noting while the image is stored in document handling the link to the released product is through a table called EcoResProductImage.
Here is a quick overview.
D365 July 2017 Update 8 (7.0.4565.16211)
Cheers
Lachlan
Filed under: Product information management
axmfg: Support for BOMs that includes items with different product dimensions of the same item Blog bot DAX Blogs 0 22.12.2015 19:11
DynamicsAxSCM: Product-item data management services Blog bot DAX Blogs 0 06.07.2011 17:11
dynamics-ax: Product Management with Microsoft Dynamics AX 2012 - Part III Blog bot DAX Blogs 0 17.05.2011 17:11
Вопрос про Demand Planner slava09 DAX: Функционал 4 25.09.2006 11:43
Часовой пояс GMT +3, время: 17:14.
