Старый 29.07.2017, 22:17   #1
dynamicsaxbi: Publish the Entity Store database on Azure SQL Server
Источник: https://blogs.msdn.microsoft.com/dyn...re-sql-server/
This step involves deploying an Entity Store database onto your Azure SQL Server created in the previous step. Before you proceed, be sure to process the Aggregate Measurements using the Dynamics 365 Administrative Tools to populate the database.  Use the following steps to seed the Entity Store database with sample data for the Application Suite's...
emeadaxsupport: Configure SSRS for load balancing in your Azure deployment Blog bot DAX Blogs 0 26.06.2015 21:11
East Ocean - Technical: Migrating SQL Database to SQL Azure Blog bot Dynamics CRM: Blogs 0 29.02.2012 14:11
Danny Varghese: SQL Server Clustering Blog bot Dynamics CRM: Blogs 0 24.06.2011 18:11
NAV Team: Microsoft Dynamics NAV and SQL Server Database Compression Blog bot Dynamics CRM: Blogs 0 11.02.2011 17:52
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics NAV 2009 Blog bot Dynamics CRM: Blogs 0 04.06.2010 13:21
Часовой пояс GMT +3, время: 05:54.
