Старый 20.07.2017, 08:11   #1
stoneridgesoftware: Using ‘Organize Project by Element Type’ for New Solutions in Dynamics 365 for Operations Development
Источник: https://stoneridgesoftware.com/using...s-development/
I was recently developing a new custom solution in Dynamics 365 for Operations. After adding a few new elements I noticed that they were just being added to the project solution and were not being categorized. I like having categorization, especially if there are a large number of elements in the solution. You can get these elements organized by type by doing the following.
My new project includes a table, three classes, and report.
To organize by element:
  1. Go to Tools – Options
  2. Find the Dynamics 365 tab and select Projects
  3. Check Organize projects by element type
  1. Click OK
One thing you will notice is that if you already have elements in your project they won’t get organized.  However, if you add any new items then those will. If you forget to check this property before you start adding elements to the project you can still get the organized by manually creating the folders.
Right-click on the project name and select Add – New folder
After creating the new folders select the objects and drag them into the element type folder. Then all elements are organized by type and any new ones created will be added to the appropriate folder.
Pretty simple, but if you are new to Dynamics 365 for Operations development you can spend a lot of time digging through all of the properties trying to find the one you are looking for.
stoneridgesoftware: Microsoft Dynamics 365 – Right around the Corner Blog bot DAX Blogs 0 10.10.2016 21:13
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 12 Blog bot Dynamics CRM: Blogs 0 30.01.2013 01:11
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics NAV 2009 Blog bot Dynamics CRM: Blogs 0 04.06.2010 13:21
Часовой пояс GMT +3, время: 15:57.
