Старый 28.12.2016, 16:11   #1
Kashperuk Ivan: Configuration tip: Warehouse mobile devices portal Native application in Azure Active Directory
Источник: http://kashperuk.blogspot.com/2016/1...se-mobile.html
Setting up the Warehouse mobile devices portal is a relatively simple process, and is described in detail on the corresponding wiki:https://ax.help.dynamics.com/en/wiki...ics-ax/However, now and again I would get complaints around the authorization process not working properly, or asking for interactive login, both of which shouldn't be
Kashperuk Ivan: Tips: Configuring Warehouse Mobile Devices Portal after installation on CTP7 and CTP8 builds of the latest Dynamics AX release Blog bot DAX Blogs 0 05.02.2016 14:11
Kashperuk Ivan: Tutorial: Warehouse Mobile Devices Portal for the latest version of Microsoft Dynamics AX Blog bot DAX Blogs 0 28.01.2016 16:11
DynamicsAxSCM: Warehouse Mobile Device Portal Blog bot DAX Blogs 0 23.02.2015 22:12
Kashperuk Ivan: Tip: Connecting the Warehouse management device portal to a different company or partition in Dynamics AX Blog bot DAX Blogs 0 03.12.2014 19:11
Часовой пояс GMT +3, время: 03:40.
