Старый 03.11.2016, 03:34   #1
stoneridgesoftware: Changing a Relationship Precedence in Dynamics AX
Источник: https://stoneridgesoftware.com/chang...n-dynamics-ax/
Have you ever been in a scenario where a data source has more than one relationship to a table it is being linked to? I have. It wasn’t a problem until I wanted the second relationship to take priority.
So the real question is, how to specify what relationship should the table use?
In my example, on the InventTable I have multiple relationships defined. Please note though:
InventTable.AlcholoManufacturerID_RU == VendTable.AccountNum InventTable.PrimaryVendorId == VendTable.AccountNum
On my form: EcoResProductDetailsExtended, I added VendTable as a data source.
Well, how does AX know which relationship I want take precedence? By default, AX uses the first one. In this case, the AlcoholManufacturer_RU relationship takes precedence.
To change what relationship takes precedence I overloaded the init() method.
  1. First, you must tell the data source what relationship you want to use.
vendtable_ds.joinRelation("PrimaryVendTable"); 2. Second, you must make the relationship the active relationship.
VendTable_ds.linkActive(); 3. Third, you must execute the query.
vendtable_ds.executeQuery(); </p> It is important to note, this must all be done before the super(). By following these simple steps, you will set a tables relationship precedence on a data source with more than one defined relationship.
Your init() method should look like the following.
public void init() { vendtable_ds.joinRelation("PrimaryVendTable"); VendTable_ds.linkActive(); vendtable_ds.executeQuery(); super(); }
axforum blogs: Квест: Подружим Dynamics Ax 2009 Sp1 RU7 c SharePoint Foundation 2010 Blog bot DAX Blogs 4 16.10.2017 17:50
stoneridgesoftware: TFS Code Repository and Dynamics AX Blog bot DAX Blogs 0 16.06.2016 16:11
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 12 Blog bot Dynamics CRM: Blogs 0 30.01.2013 01:11
Часовой пояс GMT +3, время: 13:35.
