Старый 12.07.2016, 08:11   #1
dynamicscpm: Management Reporter 2012 CU15 Hotfix 3 Now Available
Источник: https://blogs.msdn.microsoft.com/dyn...now-available/
A recommended hotfix rollup is now available for Management Reporter 2012 CU15. This hotfix contains two fixes that apply to all ERPs that relate to report generation, and several other performance fixes for Microsoft Dynamics GP. This hotfix requires CU15 to be installed first. There is only an update to the server components. The changes will take effect after the...
dynamicscpm: Management Reporter 2012 CU 13 Performance Hotfix Now Available Blog bot DAX Blogs 0 13.10.2015 00:11
dynamicscpm: Management Reporter 2012 CU11 - Hotfix 2 Now Available Blog bot DAX Blogs 0 27.01.2015 05:11
dynamicscpm: Migrating to Management Reporter 2012 Blog bot DAX Blogs 0 24.05.2012 01:13
dynamicscpm: How can you get Management Reporter 2012? Blog bot DAX Blogs 0 11.04.2012 18:11
dynamicscpm: Management Reporter 2012 Released! Blog bot DAX Blogs 0 31.03.2012 23:11
Часовой пояс GMT +3, время: 15:46.
