Старый 29.04.2016, 02:18   #1
newdynamicsax: How do I access an extended table field from C#?
Источник: https://community.dynamics.com/ax/b/...e-field-from-c
Say you have a table that contains a set of fields in a base model. Then, in another model, you add some new fields as extensions to the table metadata. It seems like a legitimate ask to be able to access...(read more)
dynamicsaxhints: When is it best to use Table::find().Field or select Field from Table? Blog bot DAX Blogs 0 22.03.2016 09:11
fatihdemirci: How to get table field properties from X++ Blog bot DAX Blogs 0 26.12.2015 12:15
dynamicsaxtraining: How to access field in a table using this field id Blog bot DAX Blogs 0 09.12.2010 02:13
Часовой пояс GMT +3, время: 23:45.
