|  29.01.2010, 21:52 | #1 |
| Участник |
			The Connecting to NAV Web Services series is coming to an end. I think I have covered the majority of platforms from which you would like to connect and use NAV Web Services – some things are easy and some things are a little harder. I did not cover Flash nor did i cover things like the iPhone or iPod Touch, primarily because I don’t think the demand is there. If I have forgotten any platform/language please let me know and if the demand is there I might make something work. Why VBScript? Including VBScript makes it possible to do Web Services from scripting like login, shutdown and maintenance scripts. I know that VBScript can also be used from certain browsers but the real idea behind including VBScript here is to enable command line scripts. Please read this post to get a brief explanation of the scenario I will implement in VBScript. Please read this post about how to connect to NAV Web Services from Javascript to get an overall explanation about XML Web Services and how to do things without having proxy classes generated etc. The primary difference between Javascript and VBcript is actually syntax – most of the things are done in a similar way. The Script file I created a file called TestWS.vbs and the code to implement the scenario looks like: function InvokeNavWS(URL, method, nameSpace, returnTag, parameters) Set xmlhttp = CreateObject("MSXML2.XMLHTTP") request = "<Soap:Envelope xmlns:Soap="""+SoapEnvelopeNS+"""><Soap:Body><"+method+" xmlns="""+nameSpace+""">"+parameters+"</"+method+"></Soap:Body></Soap:Envelope>" ' Use Post and non-async xmlhttp.open "POST", URL, false xmlhttp.setRequestHeader "Content-type", "text/xml; charset=utf-8" xmlhttp.setRequestHeader "Content-length", len(request) xmlhttp.setRequestHeader "SOAPAction", method ' send request synchronously xmlhttp.send request ' 200 == OK if xmlhttp.status = 200 then Set xmldoc = xmlhttp.responseXML xmldoc.setProperty "SelectionLanguage", "XPath" xmldoc.setProperty "SelectionNamespaces", "xmlns:tns="""+nameSpace+"""" Set InvokeNavWS = xmldoc.selectNodes("//tns:"+returnTag) else Set InvokeNavWS = nothing end if end function ' Get the Company list function SystemService_Companies() Set SystemService_Companies = InvokeNavWS(systemServiceURL, "Companies", systemServiceNS, "return_value", "") end function ' Read one customer function CustomerPage_Read(no) Set CustomerPage_Read = InvokeNavWS(CustomerPageURL, "Read", CustomerPageNS, "Customer", "<No>"+no+"</No>") end function ' Read Customers function CustomerPage_ReadMultiple(filters) Set CustomerPage_ReadMultiple = InvokeNavWS(CustomerPageURL, "ReadMultiple", CustomerPageNS, "Customer", filters) end function sub display(str) WScript.echo str end sub baseURL = "http://schemas.xmlsoap.org/soap/envelope/" systemServiceNS = "urn:microsoft-dynamics-schemas/nav/system/" customerPageNS = "urn:microsoft-dynamics-schemas/page/customer" Set Companies = SystemService_Companies() display "Companies:" for i = 0 to Companies.length-1 display Companies(i).text next cur = Companies(0).text customerPageURL = baseURL+escape(cur)+"/Page/Customer" display "" display "URL of Customer Page:" display customerPageURL Set Customer10000 = CustomerPage_Read("10000") display "" display "Name of Customer 10000: "+Customer10000(0).childNodes(2).firstChild.nodeValue Set Customers = CustomerPage_ReadMultiple("<filter><Field>Country_Region_Code</Field><Criteria>GB</Criteria></filter><filter><Field>Location_Code</Field><Criteria>RED|BLUE</Criteria></filter>") display "" display "Customers in GB served by RED or BLUE warehouse:" for i = 0 to Customers.length-1 display Customers(i).childNodes(2).firstChild.nodeValue next display "" display "THE END" The similarity to the Javascript sample is huge (since I am using the same object model), the biggest differences are:
 Using the command: C:usersfreddyk>SCript /nologo testws.vbs I get the following:   and of course you can now to things as redirecting the output to a file and typing or searching in that file:   This is something network administrators are experts in doing – I won’t try to compete in any way. I hope this is helpful. Good luck Freddy Kristiansen PM Architect Microsoft Dynamics NAV Подробнее
				__________________ Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
