#1 |
Leon's CRM Musings: TFS For CRM Development Management
Источник: http://leontribe.blogspot.com/2014/0...anagement.html
============== Sometimes on CRM projects you get asked to do things outside of your usual routine. On my latest project I am setting up Team Foundation Server (TFS) so the development and testing teams can use it to:
What Information Can We Capture? TFS has a number of ‘entities’ to manage development. These are:
In my case I created Areas for:
Iterations are the build cycles. In my case, I have two cycles: a configuration cycle and and development cycle. The only information we capture on the Iteration is its name and whether it is part of a hierarchy (like Areas, Iterations can be structured like a tree). The Work Items are, in some ways similar to CRM Activities in that, while Activities are treated as a group in some ways e.g. when constructing queries, the sub-types also get individual treatment, specifically when storing information. A User Story is something we are working to achieve with the development. So, for me, this covered two aspects: the development modules and the business requirements. Here is the User Story form in TFS. For my purposes the following fields were useful:
Here is a Task in TFS. Again, we have the Title, Assigned To, State, Area, Iteration, Details and Links areas, as with User Stories, but we also have:
This is similar to the User Story form and the fields are used in, essentially, the same way. Shared Steps are common testing steps which can be used across multiple test processes. In my case, the testing of a business requirement required only the capture of a pass/fail with an Issue raised in the case of a failure so I did not use these. Test Cases, surprisingly, I did not use. Mainly because, while it is possible to create a Test Case within TFS, it is not possible to create Test Case steps; these are created in Microsoft Test Manager (MTM), a separate product and automatically brought in to TFS. Given my simple test requirements, I avoided using Test Cases with the pass/fail being recorded via the Status of the business requirement. Linking the Entities In the case of Areas and Iterations, these have a 1:N relationship to Work Items. For the Work Items themselves, any Work Item can be linked to any other Work Item in a way similar to Connections in CRM. This means all manners of structures can be created in TFS. The key consideration in determining the right structure is working out what reports are likely to be generated from the system. In my case, the structure was like this: So, for example in ‘Iteration 2’, the development iteration, we develop an SMS Module which meets the business requirements regarding the sending of SMS from the system. The tasks for the module are defined and, when the system is tested, issues are logged against the development module for the developer to action. Within TFS, we now have a one-stop shop for the progress of development. We can open up the development module record and see all related information. By enforcing a policy of associating a Work Item to every code check-in (part of the team setup) we can also see the code being checked in from the development module record. My Departure From the Norm While a reasonably sensible structure, this does deviate from the ‘norm’. Generally, the development tasks come under the business requirement (User Story). For me, there were over 1,000 business requirements so this meant a lot of bookkeeping for minimal gain. The only consequence of my approach is some of the out of the box reports, which assume a certain structure, will not work quite as expected. Reporting There are three main approaches to reporting with TFS:
From Visual Studio, you can also export queries to Excel. This option also allows for republishing back to TFS, which is great for mass-editing. Finally, is those are insufficient, SSRS reports can be written as the information in TFS can be queried via SQL. Conclusions If your development team is already using TFS for source control, consider also using it for development management. The developers can remain in the products they are used to (Visual Studio and TFS) and the project manager can gain visibility of progress. Also, if you have geographically separate groups developing, this provides a common place to review progress. Finally, I would like to thank the ‘Davids’ (David Watson and David Jansen) of Microsoft for walking me through TFS. Without their patience I would have have half the knowledge and twice the frustration with the product and their generosity of time is greatly appreciated. Источник: http://leontribe.blogspot.com/2014/0...anagement.html
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
