Старый 04.09.2008, 16:06   #1
Model Based Testing
Кто-то из присутствующих когда-то имел дело с тестированием на основе модели?
Специфически, Data-Driven разновидности, когда выполняется один и тот же тест, но с применением большого количества различных данных.
Может посоветуете, что почитать про это?
И вообще - интересны мысли о этом подходе.
Ессно, это все будет применяться для тестирования АХ, если это имеет значение.
Старый 04.09.2008, 18:05   #2
belugin is offline
belugin
Аватар для belugin
4,622 / 2925 (107) +++++++++
Записей в блоге: 5
попробуй поспрашивать где-то в районе
http://software-testing.ru/
http://tester.com.ua/
Старый 02.01.2009, 16:33   #3
belugin is offline
belugin
Аватар для belugin
Записей в блоге: 5
http://www.dotnetrocks.com/default.aspx?showNum=408
ames Whittaker brings a practical approach to testing, and his viewpoint may surprise you.
James A. Whittaker, now a Software Architect at Microsoft, has spent his career in software testing. He was an early thought leader in model-based testing where his PhD dissertation from the University of Tennessee became a standard reference on the subject. While a professor at Florida Tech, he founded the world’s largest academic software testing research center and helped make testing a degree track for undergraduates. Before he left Florida Tech, his research group had grown to over 60 students and faculty and had secured over $12 million in research awards and contracts. During his tenure at FIT he wrote How to Break Software and the series follow-ups How to Break Software Security (with Hugh Thompson) and How to Break Web Software (with Mike Andrews). His research team also developed the highly acclaimed runtime fault injection tool Holodeck.
Dr. Whittaker currently works at Microsoft as an architect for Visual Studio Team System where he is busy transforming his testing ideas into tools and techniques for developers and testers. He dreams of a future in which software just works.
daxis: What’s new in Set based operations in Dynamics Ax 2009 Blog bot DAX Blogs 0 01.04.2009 18:05
axaptapedia: Unit Testing Blog bot DAX Blogs 0 19.11.2007 03:24
dynamicsmatters: Dynamics Ax Base Data model Part I Blog bot DAX Blogs 0 02.12.2006 23:49
Satya: Dynamics Customer Model Poster and White Paper on Roles Based Business Productivity Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 06:44.
