Старый 20.03.2016, 06:30   #1
organicax: Deleting a shipment in WMS
Источник: http://organicax.com/2016/03/19/dele...ipment-in-wms/
When you are working in the warehouse there are often issues that you need to correct because the physical environment change, the shipment wasn’t supposed to go, the inventory wasn’t found etc. So you need to be able to tell the system about things to get it back in line to help you plan. For example if a shipment was released but it wasn’t supposed to be you might want to delete it so it doesn’t get worked on.
Here is a quick look at deleting a shipment.
AX2012 R3 CU9
Now it’s worth pointing out there are more variations of states a shipment could get into. In these examples if there was work it hadn’t started to be worked on so we’ll look at those in later examples.
Cheers
Lachlan
Filed under: Warehouse management
organicax: WMS Wave template – line threshold Blog bot DAX Blogs 0 15.03.2016 23:11
organicax: Management of sales – multiple deliveries – partial ship – wms Blog bot DAX Blogs 0 10.03.2016 23:14
organicax: Purchase items using auto batch numbers – wms Blog bot DAX Blogs 0 08.03.2016 21:16
organicax: WMS Wave template – Shipment threshold Blog bot DAX Blogs 0 07.03.2016 16:11
DynamicsAxSCM: WMS in Microsoft Dynamics® AX 2009. Shipping Process Overview Blog bot DAX Blogs 4 21.04.2009 00:30
Часовой пояс GMT +3, время: 22:43.
