Старый 14.04.2015, 15:11   #1
axStart: Violation of PRIMARY KEY constraint ‘PK_ModelElementData_ElementHandle’ with AX 2012R2 CU8
Источник: http://www.axstart.com/violation-of-...ax-2012r2-cu8/
Last week, I was upgrading AX 2012 R2 CU7 to CU8 and ran into a model store error. The error was similar to http://blogs.msdn.com/b/axsupport/ar...x-2012-r2.aspx
It scared the hell out of me! First thing that came to mind was: is my model store corrupt in production?
But the source of the problem was indeed different; found out that the issue was label files.
In the AX 2012 R2 CU7, the DMF labels were missing, so this was fixed by adding them manually (see picture below)
This means that my AX2012 R2CU7 model store was consistent.
Label files cannot be deleted directly from the AOT. In such cases, the following workaround is necessary:
  1. Create a new model
  2. Move the labels to this new model
  3. Finally, delete this model
emeadaxsupport: Violation of PRIMARY KEY constraint 'PK_ModelElementData_ElementHandle' error installing some hotfixes on Microsoft Dynamics AX 2012 R2 Blog bot DAX Blogs 0 08.01.2014 22:13
ax-erp: Choosing a Primary Key: Natural or Surrogate? Blog bot DAX Blogs 0 18.12.2012 02:11
emeadaxsupport: Dynamics AX 2009 Retail: Violation of PRIMARY KEY constraint while replicating an A-job Blog bot DAX Blogs 0 09.02.2012 17:11
Часовой пояс GMT +3, время: 07:00.
