Старый 18.03.2015, 22:12   #1
kurthatlevik: Dynamics AX 2012: Warming up for presales demo
Источник: https://kurthatlevik.wordpress.com/2...presales-demo/
To really impress potential buyers of Dynamics AX, it is important that we are capable to show that AX 2012 responds fast. We normally use the Contoso hyper-v demo environment, and our laptops have limited resources. Starting a demo on a cold system, we often see that forms takes some time to operate in optimal performance. If you already have opened a form, it is much faster the second time you open it.
So how can we give the users a view of a fast system without manually opening all the forms prior to the demo?
We can warm them up J. I use the following job-script to open and close all the forms I’m planning to use. I just traverse through the AOT, and open the form, and then I close them again.
static void WarmupRF(Args _args){ //This code is for "warming" up all RF* forms and code I have in the VAR-layer UtilElements e; TreeNode treeNode; FormRun formRun; Args args = new Args(); while select e where e.utilLevel == UtilEntryLevel::var //
msdyncomm: Microsoft Dynamics AX 2012 R3 for Service Industries demo: Win the right projects Blog bot DAX Blogs 0 25.06.2014 05:22
dynamics-ax: Modeling the world, with Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 25.01.2011 09:11
Часовой пояс GMT +3, время: 08:35.
