Старый 18.10.2014, 17:47   #1
ist is offline
ist
Default dimension sttribute value as a field on grid
Hi All,
Is there any way to display a field part of default dimension to the grid form control without using display method? I can do this through display method but the user cannot do filtering by this field therefore it is not appropriate.
Here is my display method approach:
 display public DimensionValue displayDefaultDimCostCenter()
     DimensionAttributeValueset     dimAttrValueSet;
     DimensionAttributeValueSetItem dimAttrValueSetItem;
     DimensionAttributeValue        dimAttrValue;
     DimensionAttribute             dimAttr;
     select firstOnly dimAttr
         where dimAttr.Name == "CostCenter";
     select dimAttrValueSet
         where dimAttrValueSet.RecId == this.DefaultDimension
         join dimAttrValueSetItem
             where dimAttrValueSetItem.DimensionAttributeValueSet == dimAttrValueSet.RecId
             join dimAttrValue
                 where dimAttrValueSetItem.DimensionAttributeValue == dimAttrValue.RecId
                    && dimAttrValue.DimensionAttribute             == dimAttr.RecId;
     return dimAttrValueSetItem.DisplayValue;
But I would like to add CostCenter default financial dimension (outlined to the screen shot) to a grid control in my custom form which datasource is SalesTable, so the user can do filtering and sorting the grid control by CostCenter.
Is there any way to do that?
Thank you in dvance.
Миниатюры
ax_gfm_framework_team: Dimension defaulting in accounting distributions, Part 3 - Splitting and defaulting using Financial dimension default templates and Main account allocation rules Blog bot DAX Blogs 0 18.12.2013 09:11
sumitsaxfactor: Replace a Financial Dimension in Default Dimensions–Condensed [AX 2012] Blog bot DAX Blogs 0 23.11.2012 23:13
sumitsaxfactor: Replace a Financial Dimension in Default Dimensions [AX 2012] Blog bot DAX Blogs 0 18.01.2012 11:11
dynamicsaxtraining: Item setup: Inventory dimension group Blog bot DAX Blogs 1 05.10.2010 15:35
Khue Trinh: Setting up a link between a financial dimension and the site inventory dimension Blog bot DAX Blogs 0 27.09.2010 13:05
Часовой пояс GMT +3, время: 19:36.
