Старый 05.09.2014, 04:43   #1
axcompapp: Easily set up an Azure demo environment for mobile apps
Источник: http://blogs.msdn.com/b/axcompapp/ar...bile-apps.aspx
Trying out and demonstrating the Dynamics AX 2012 R3 companions apps just became a lot easier using Lifecycle Services for Dynamics AX to deploy AX 2012 R3 VMs on Azure.
1. As a first step, LCS makes it very easy to deploy an Azure-based VM with AX 2012 R3 already installed. Details are here http://technet.microsoft.com/en-us/l.../dn741581.aspx
2. Then simply follow the config steps to connect the AX phone and tablet apps to your AX VM in Azure: https://mbs.microsoft.com/files/cust...urePartner.pdf
Now you'll have a trial / demo environment (accessible from anywhere) that you can tweak and use to explore the apps. You can turn the VM on or off as needed.
Give it a try and we look forward to hearing your feedback!
emeadaxsupport: Connecting Retail Components on an External Computer to the Microsoft Dynamics AX R3 Azure Lifecycle Services Demo Virtual Machine Blog bot DAX Blogs 0 28.06.2014 00:13
axcompapp: Welcome to Dynamics AX Companion Apps Blog bot DAX Blogs 0 01.11.2013 11:11
fed: Net requirements update in MRP Module and Working Set of MRP Blog bot DAX Blogs 14 08.05.2012 13:09
Часовой пояс GMT +3, время: 11:33.
