Старый 25.06.2014, 12:11   #1
mfp: X++ Debugging Tips and Tricks #4 - Reading uncommitted data
Источник: http://blogs.msdn.com/b/mfp/archive/...tted-data.aspx
This next trick in the X++ Debugging Tip and Tricks seriesis invaluable when stuck deep in a debugging session, and want to verify that the SQL statements being executed has the intended behavior.For illustrative purposes, I’ve created a small job. It updates the customer group to “40” for the customer with account number “4001”. This happens inside a transaction. I’ve also added a breakpoint statement to jump to the debugger inside the transaction.
When running the job the debugger opens:
Now, if we go the SQL Server Management Studio and execute a select statement to validate that the field was correctly updated, we will notice that it still has the old value:
This should not be a surprise, as the transaction has not been committed yet. However; that shouldn’t block our noble purpose. By adding the keyword “nolock” to the query, we instruct SQL to read the uncommitted data, and voila, we get the results we expect:
One additional piece of advice is related to more complicated SQL statements: You have to add the nolock keyword to every joined table.
This can be a true life saver when debugging. In fact I used this heavily the past few weeks where I've been working on the new Warehouse Management module in R3.
Старый 25.06.2014, 21:39   #2
Logger is offline
3,996 / 3293 (117) ++++++++++
By adding the keyword “nolock” to the query, we instruct SQL to read the uncommitted data, and voila, we get the results we expect:...
Попробовал бы он такое в оракле провернуть
Фига с два. Но не будем о покойничке....
А еще этот способ бывает полезен, чтобы блокировки лишние не ставить при чтении. Правда с выходом уровнем изоляции транзакций Snapshot isolation мое замечание устарело.
Старый 25.06.2014, 22:39   #3
Wamr is offline
Wamr
1,737 / 868 (32) +++++++
Записей в блоге: 7
А можно и настройками запроса
За это сообщение автора поблагодарили: fed (3), Logger (3), Link (4), gl00mie (3).
Старый 28.06.2014, 00:24   #4
Да. я обычно просто перед запросами в окне пишу
SET TRANSACTION ISOLATION LEVEL READ UNCOMMITTED
а то геморно как-то, nolock писать по двести раз
mfp: X++ Debugging Tips and Tricks #2 – xSession::xppCallStack() Blog bot DAX Blogs 6 23.11.2015 11:37
mfp: X++ Debugging Tips and Tricks #3–Conditional breakpoints Blog bot DAX Blogs 1 20.11.2013 11:18
mfp: X++ Debugging Tips and Tricks Blog bot DAX Blogs 2 24.09.2013 13:01
mfp: X++ Debugging Tips and Tricks #1 – Breakpoint in Info.add() Blog bot DAX Blogs 1 24.09.2013 11:00
Microsoft Dynamics CRM Team Blog: Data Migration Manager Tips and Tricks Blog bot Dynamics CRM: Blogs 0 02.09.2008 22:05
Часовой пояс GMT +3, время: 10:23.
