Старый 04.11.2015, 04:57   #1
Dynamics AX Sustained Engineering: New version of Microsoft Dynamics AX Intelligent Data Management Framework (IDMF) is now available on LCS
Источник: http://blogs.technet.com/b/dynamicsa...le-on-lcs.aspx
A new version (v 2.0.33.0) of Microsoft Dynamics AX Intelligent Data Management Framework (IDMF) is now available on LCS Tools.
Below are the list of issues that has been fixed in this new version:
IDMF - Purge job deletes all records due to missing validation:
There is no validation on the Value to determine if we want it to be BLANK or ‘’ (two single quotes) which leads to delete all records from the table not just the ones having blank SalesId.
Value validation has been improved so that we don’t delete data that we didn’t expect to delete.
IDMF - Selecting a date time value is tricky and can result in incorrect data being stored:
The issue has been fixed to ensure that control works correctly and users can easily select a date time value properly and the value saved is correct.
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2013 Update Rollup 2 Blog bot Dynamics CRM: Blogs 0 15.04.2014 01:15
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 13 Blog bot Dynamics CRM: Blogs 0 27.03.2013 22:12
Intelligent Data Management Framework for Microsoft Dynamics AX: Installation and Administration Guides Vadik DAX: База знаний и проекты 11 12.11.2010 12:35
AX UK: Intelligent Data Management Framework for Microsoft Dynamics AX (BETA release) Blog bot DAX Blogs 0 26.06.2009 03:16
Часовой пояс GMT +3, время: 08:12.
