Старый 15.04.2014, 01:15   #1
Axilicious:Release Management – Customize timouts on default tools / actions
Источник: http://www.ksaelen.be/wordpresses/dy...tools-actions/
In Release Management for Visual Studio 2013, you can customize your tools and actions to work with. The last few days I was creating a Release template for use with Dynamics AX 2012. One of the actions early in the template is backing up the database. ( Of course you need to backup first ) And there I faced a little inconvenience: I could not adjust the timeout of the restore action but this was needed as an AX model store database restore could not be completed within 5 minutes.
So I decided to go back to the Restore SQL Database action and adjust the timeout setting. But hey, you are unable to do that on the default tool!
There is a parameter to setup default timeouts, but this only applies when creating new actions. So that doesn’t help a lot.
So for me, the most convenient and simple solution was to copy the tool that is available out of the box and create a new one from it. Then you do have the ability to set the timeout.
dynamicscpm: Management Reporter Web Viewer as default - Management Reporter RU5 Blog bot DAX Blogs 0 25.04.2013 18:11
dynamicscpm: Management Reporter web viewer Q&A – Management Reporter RU3 release preview Blog bot DAX Blogs 0 25.10.2012 06:12
DynamicsAxSCM: Troubleshooting the product release process Blog bot DAX Blogs 0 05.10.2012 17:11
Microsoft Dynamics CRM Team Blog: Solutions & Release Management Blog bot Dynamics CRM: Blogs 0 07.07.2011 22:12
Часовой пояс GMT +3, время: 21:45.
