Старый 19.03.2014, 00:13   #1
atinkerersnotebook: Rename Product Dimensions To Match Your Business
Источник: http://atinkerersnotebook.com/2014/0...your-business/
Originally posted on Dynamics AX Tip Of The Day:
Product Dimensions within Dynamics AX are great because they give you four extra elements that you can use to segregate out all of your products, and you can start reducing the number of base product codes that you use. By default the main three dimensions are named Size, Color, and Style, but if you think of your product dimensions in different terms, don’t disregard this feature, because you can rename them to be whatever you like.Now you can build your product dimensions however you like.
View original 210 more words
atinkerersnotebook: Using Vendor Requests to Manage On-boarding New Vendors Blog bot DAX Blogs 1 22.10.2013 02:24
atinkerersnotebook: Using PowerPivot to Analyze Dynamics AX Data Blog bot DAX Blogs 1 05.10.2013 07:23
atinkerersnotebook: Using Service Management to Track Service Orders Blog bot DAX Blogs 1 25.08.2013 19:16
atinkerersnotebook: Configuring Lean Manufacturing in Dynamics AX 2012 Blog bot DAX Blogs 1 12.08.2013 00:15
DynamicsAxSCM: Product-item data management services Blog bot DAX Blogs 0 06.07.2011 17:11
Часовой пояс GMT +3, время: 16:03.
