Старый 22.01.2014, 21:11   #1
palleagermark: Setup a Manged WPF control for drag 'n' drop
Источник: http://www.agermark.com/2014/01/setu...ag-n-drop.html
In an earlier post I have made an example of to make a form with a drag 'n' drop enabled WPF control.
Now, here is the initialization code to put a nice image in the control (which is a PictureBox control now), and set the transparency color of the control to the background color of , in this case, the tab page it is on:
private void initDropControl()
Image resImg;
System.Drawing.Image img;
System.Drawing.Color backGroundColor;
int colorR;
int colorG;
int colorB;
System.Windows.Forms.PictureBox dropControl;
// Get handle to the control
dropControl = ManagedHostDropFile.control();
// Setup event handlers for the control
dropControl.add_DragDrop(new ManagedEventHandler(this, 'dropFile_DragDrop'));
dropControl.add_DragEnter(new ManagedEventHandler(this, 'dropFile_DragEnter'));
dropControl.set_AllowDrop(true);
// Load the AX resource image
resImg = new Image();
resImg.loadResource(12452);
// Get the tab page background color
backGroundColor = System.Drawing.ColorTranslator::FromOle(TabPageLoadFile.backgroundColor());
colorR = backGroundColor.get_R();
colorG = backGroundColor.get_G();
colorB = backGroundColor.get_B();
// Set the transparancy color of the AX resource image to the tab page background color
resImg.transparent(true, colorR, colorG, colorB);
// Create an image object that the WPF control is able to load
img = System.Drawing.Image::FromHbitmap(new System.IntPtr(resImg.exportBitmap()));
// Add the image to the control
dropControl.set_Image(img);
Axilicious:Hosting custom WPF calendar control in AX 2012 Blog bot DAX Blogs 0 20.05.2013 18:11
palleagermark: Setup the March 2013 demo machine for VirtualBox Blog bot DAX Blogs 0 02.04.2013 23:12
emeadaxsupport: AX for Retail 2012 R2: Adding a Custom User Control to the POS Blog bot DAX Blogs 0 27.02.2013 07:14
palleagermark: Parsing a custom parameter from a user control to a data set used on another user control Blog bot DAX Blogs 0 28.10.2010 12:05
axStart: Microsoft Dynamics AX 2009 White Paper: Team Foundation Server Version Control Setup Blog bot DAX Blogs 0 27.07.2008 13:06
Часовой пояс GMT +3, время: 20:48.
