Старый 17.01.2014, 00:15   #1
Bug: Drag-n-Drop Creates New Element In Enums With Duplicate Values
Источник: http://alexvoy.blogspot.com/2014/01/...lement-in.html
Bug in AX 2012 R2.
When you use drag-n-drop in AOT to create a new element for a enum, it creates this element with the exactly same value.
But all enum values must be unique.
It can lead to eventual errors in run time.
Please send a bug report to Microsoft.
axcoder: Did you know, that you can drag and drop from debugger? Blog bot DAX Blogs 0 27.04.2012 16:11
dax-lessons: Easy drag and drop – files [Document Management] with minimum X++ Coding [Dynamics AX] Blog bot DAX Blogs 0 10.04.2011 08:19
Muhammad Ali Khan: Add More Values to Duration(Drop-Down) In MS-CRM 4.0 Task Entity Blog bot Dynamics CRM: Blogs 0 24.01.2010 19:05
paruvella: Dynamics Ax Document Handling For The Mails Using Drag n Drop Blog bot DAX Blogs 0 20.11.2009 20:05
jinx: Drag & Drop in Masken Blog bot DAX auf Deutsch 0 16.10.2007 16:10
Часовой пояс GMT +3, время: 06:03.
