Старый 25.09.2013, 12:29   #1
Stitch_MS is offline
Stitch_MS
Аватар для Stitch_MS
397 / 483 (17) +++++++
! AX 2012: не работают отчеты, бизнес встал
(AX 2012 CU5, Kernel 6.0.1108.5628, Application 6.0.1108.4316)
Уважаемые коллеги - кто-нибудь сталкивался с подобной ошибкой при печати отчетов?
The formatter threw an exception while trying to deserialize the message: There was an error while trying to deserialize parameter http://tempuri.org/:queryBuilderArgs. The InnerException message was 'Element 'http://tempuri.org/:queryBuilderArgs' contains data from a type that maps to the name 'http://schemas.datacontract.org/2004/07/XppClasses:SRSQueryBuilderArgs'. The deserializer has no knowledge of any type that maps to this name. Consider using a DataContractResolver or add the type corresponding to 'SRSQueryBuilderArgs' to the list of known types - for example, by using the KnownTypeAttribute attribute or by adding it to the list of known types passed to DataContractSerializer.'. Please see InnerException for more details.
Вчера штатный разработчик обновил билд:
... Ax Prod has been updated to build 1.1.5.0.
All AOS’es were stopped during deploy of new code (22:30-23:30).
No security roles were imported from the USR layer.
No services were refreshed.
No reports were deployed.
EP were not deployed.
VS assemblies were deployed on all AOS servers.
The build included a MS fix for the batch processing."
Пользователи нервничают. Некоторые сильно. Подскажите хоть, куда копать - Гугл ничего не нашел.
Спасибо.
ssrs, отчеты, ax2012
kamalblogs: SSRS Tip: Using invisible parameters in contracts – Dynamics AX 2012 Blog bot DAX Blogs 2 30.09.2013 17:50
Sample Design Patterns: Book Give-away: 'Microsoft Dynamics AX 2012 Security How-To' Blog bot DAX Blogs 0 13.12.2012 01:13
sumitsaxfactor: Create Your First Custom Service [AX 2012] Blog bot DAX Blogs 0 19.05.2012 19:14
ukax: AX 2012 Training content available on CustomerSource Blog bot DAX Blogs 0 09.09.2011 23:12
Часовой пояс GMT +3, время: 10:57.
