Старый 19.04.2013, 16:11   #1
Troubleshooting with deploying MS Dynamics AX 2012 R2 retail online store
Источник: http://axbilling.blogspot.com/2013/0...loying-ms.html
<div dir="ltr" style="text-align: left;" trbidi="on">This post is about my experiments with deploying retail online store for MS Dynamics AX 2012 R2.
Here some issues concerning possible problems that are not included in official document (http://technet.microsoft.com/en-us/l.../jj991927.aspx):
1. Name of SQL instance.
You may have some problems with creating online store databases if you have no default SQL instance on server ("local"). In oob-settings.xml file you can find these parameters:
So, the parameter values mean that all databases will be created in localhost instance.
Be careful that if you want to create these databases in the instance with name like "servername\notdefaultinstance1" you recieve errors later. It's all because these parameters are used not only for creating the databases themselves, but for example for creating windows security groups - here is a piece of oob-topology.xml file:
So, you must install default SQL instance on your server, or you can manually find where parameters ...ServerName are used in oob-topology.xml file and replace the values with the right values.
2. Exception "Access is denied".
This exception could be raised during executing powershell script InstallPrereqs-SPFarm.ps1 in the moment of creating site collection "RetailProductCatalog".
You can fix it by adding "Full control" policy to user who executes powershell scripts. To do this:
1. In SharePoint Central Administration go to Application management - Manage web applications.
2. Choose application "C1 Application for Retail Store Front - Internal".
3. Click "User policy" button - click "Add user" - leave "All zones" - choose appropriate user and "Full control" permission adn click OK.
Repeat steps 1-3 for "Out of box Store front - Public" application.
To save this setting and skip all steps from InstallPrereqs-SPFarm script that have been already done you can configur<span style="background-color: white;">e oob-topology.xml file and toggle all parameters before <i>"
emeadaxsupport: AX for Retail 2012 R2: Troubleshooting the Real-time Service Blog bot DAX Blogs 0 31.12.2012 11:13
DAX: Processing U.S. Payroll with Microsoft Dynamics AX 2012 R2 Blog bot DAX Blogs 0 03.12.2012 11:11
rumicrosofterp: Dynamics AX на Convergence 2012 Blog bot Microsoft и системы Microsoft Dynamics 0 13.01.2012 11:11
Часовой пояс GMT +3, время: 01:29.
