Старый 05.11.2012, 18:11   #1
Malaysia: Renaming the primary key
Источник: http://axmas.blogspot.com/2012/11/re...imary-key.html
//Open the AOT, create a new job named CustAccountRename, and enter the
//following code.
static void CustAccountRename(Args _args)
CustTable custTable;
select firstOnly custTable
where custTable.AccountNum == '1103';
if (custTable.RecId)
custTable.AccountNum = '1103_';
custTable.renamePrimaryKey();
emeadaxsupport: Dynamics AX 2009 Retail: Violation of PRIMARY KEY constraint while replicating an A-job Blog bot DAX Blogs 0 09.02.2012 17:11
emeadaxsupport: Store connect - IDispatch error #3119: Violation of PRIMARY KEY Blog bot DAX Blogs 0 18.08.2011 18:11
kamalblogs: Using GUID as primary key in Dynamics Ax Blog bot DAX Blogs 6 05.01.2011 12:19
kamalblogs: Renaming a Primary key like ItemId in Dynamics Ax Blog bot DAX Blogs 0 15.06.2010 20:05
Часовой пояс GMT +3, время: 08:34.
