#1 |
emeadaxsupport: Retail 2012: Store Connect Pack Viewer “Cannot find deserializer” error
Источник: http://blogs.msdn.com/b/axsupport/ar...zer-error.aspx
============== If you rely on the Retail Store Connect Pack Viewer to debug your data path between headquarters and your stores you may run into this error: “Cannot find deserializer for request header type: Microsoft.Dynamics.Retail.StoreConnect.Request.Base.SCTargetRequestHeader” This is due to a problem with how the packet viewer determines if a packet is a “source” packet or a “target” packet. In previous versions, this distinction was based solely on the filename: “SERVER8HQ-114-I.tmp” vs. “SERVER8HQ-114-R.tmp”. However, there are certain scenarios in 2012 where an “I” packet should be evaluated as an “R” packet. This issue will be fixed in a future release, but in the meantime there is a very simple workaround you can do to get past the error: rename your file in your temp directory. In my case I renamed my file to “SERVER8HQ-114-R.tmp” and the Pack Viewer was able to extract the data to a subfolder: This subfolder will have XML representations of the contents which you can then load using any XML viewer. Источник: http://blogs.msdn.com/b/axsupport/ar...zer-error.aspx
| Теги |
| axretail |
