Старый 15.06.2012, 00:11   #1
sumitsaxfactor: Getting Individual Dimension Combination Values–Using Views [AX 2012]
Источник: http://sumitsaxfactor.wordpress.com/...views-ax-2012/
In my previous post, I had illustrated how we can get individual dimension combination values using DimensionStorage class. In this post, I will provide another job that utilizes a view to get individual values for a ledger dimension.
The view that has been used in DimensionAttributeLevelValueAllView. Here is the job
staticvoid sgxIndividualDimensionValuesUsingView(Args _args)
GeneralJournalAccountEntry generalJournalAccountEntry; //Table that stores ledger transactions
DimensionAttributeLevelValueAllView dimAttrView; //View that will display all values for ledger dimensions
DimensionAttribute dimAttr; //Main dimension attribute table
int i;
setPrefix(‘Ledger dimension breakup’);
whileselect generalJournalAccountEntry
i++;
if (i > 100)
break;
setPrefix(int2str(i) + “. “ + DimensionAttributeValueCombination::find(generalJournalAccountEntry.LedgerDimension).DisplayValue);
whileselect DisplayValue from dimAttrView
where dimAttrView.ValueCombinationRecId == generalJournalAccountEntry.LedgerDimension
join BackingEntityType from dimAttr
where dimAttr.RecId == dimAttrView.DimensionAttribute
switch (dimAttr.BackingEntityType)
casetableNum(DimAttributeMainAccount):
info(strFmt(“Main Account: %1″, dimAttrView.DisplayValue));
break;
casetableNum(DimAttributeOMBusinessUnit):
info(strFmt(“Business Unit: %1″, dimAttrView.DisplayValue));
break;
casetableNum(DimAttributeCustTable):
info(strFmt(“Customer: %1″, dimAttrView.DisplayValue));
break;
casetableNum(DimAttributeOMDepartment):
info(strFmt(“Department: %1″, dimAttrView.DisplayValue));
break;
casetableNum(DimAttributeHcmWorker):
info(strFmt(“Worker: %1″, dimAttrView.DisplayValue));
break;
Here is the output.
emeadaxsupport: Dynamics AX 2012 cubes - Customer dimension does not show values for Address description, Zip postal code, country or region id Blog bot DAX Blogs 0 27.04.2012 16:11
sumitsaxfactor: Getting Individual Dimension Combination Values–Dimension Storage class [AX 2012] Blog bot DAX Blogs 0 16.12.2011 18:11
Часовой пояс GMT +3, время: 08:09.
