Старый 22.05.2012, 19:11   #1
emeadaxsupport: Error while importing a user group from the Active Directory into Microsoft Dynamics AX 2012
Источник: http://blogs.msdn.com/b/axsupport/ar...s-ax-2012.aspx
We recently came across an issue where importing a Domain Local Group into Microsoft Dynamics AX 2012
raises an infolog error message:
The Active Directory user or group does not exist. Contact your network administrator.
However we don't get an error if you imported a Domain Global or Universal group instead. This is by-design.
The Domain Local scope is intended for one single domain. However the Global or Universal Group Scope has a much wider scope and visibility for usage within domains. These are the group types supported within AX 2012.
Summary:
Use only Domain Global or Universal group scopes when importing them in to Microsoft Dynamics AX 2012. For more information on the different domain group scopes please see the references section.
References:
Group Scope
Understanding Group Accounts
--author: Girish Narasoji Rao Chandrappa
Sample Design Patterns: Book Give-away: 'Microsoft Dynamics AX 2012 Development Cookbook' Blog bot DAX Blogs 1 12.05.2012 16:55
Microsoft Dynamics CRM Team Blog: The Microsoft Dynamics CRM Swiss Army Knife Blog bot Dynamics CRM: Blogs 1 19.04.2012 08:20
dynamics-ax: Modeling the world, with Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 25.01.2011 09:11
Часовой пояс GMT +3, время: 21:26.
