Старый 18.12.2013, 21:11   #1
sashanazarov: Table inheritance and collection objects
Источник: http://sashanazarov.blogspot.com/201...n-objects.html
Be aware that there is an issue with storing child table records in collection objects like List.
If you have a table hierarchy and add a child table record to a List and then try to get it back, information from parent tables is lost, along with InstanceRelationType field value.
The following job reproes the issue:
static void tableInheritanceAndListBug(Args _args)
CompanyInfo companyInfo;
List companyInfoList;
ListEnumerator companyInfoEnumerator;
companyInfoList = new List(Types::Record);
select firstOnly companyInfo;
info(strFmt(
"Orig: RecId: %1, Name: %2, InstanceRelationType: %3",
companyInfo.RecId,
companyInfo.Name,
companyInfo.InstanceRelationType));
companyInfoList.addEnd(companyInfo);
companyInfoEnumerator = companyInfoList.getEnumerator();
if (companyInfoEnumerator.moveNext())
companyInfo = companyInfoEnumerator.current();
info(strFmt(
"List: RecId: %1, Name: %2, InstanceRelationType: %3",
companyInfo.RecId,
companyInfo.Name,
Output:
Orig: RecId: 5637151316, Name: Contoso Entertainment Systems - E&G Division, InstanceRelationType: 41
List: RecId: 5637151316, Name: , InstanceRelationType: 0
The workaround is to use buf2con function to convert the table buffer to a container, save the container in the list and finally use con2buf when fetching the value with enumerator.
static void tableInheritanceAndListBugWorkaround(Args _args)
companyInfoList = new List(Types::Container);
info(strFmt(
companyInfo.RecId,
companyInfo.Name,
companyInfoList.addEnd(buf2Con(companyInfo));
companyInfo = con2Buf(companyInfoEnumerator.current());
info(strFmt(
companyInfo.RecId,
companyInfo.Name,
Output:
List: RecId: 5637151316, Name: Contoso Entertainment Systems - E&G Division, InstanceRelationType: 41
За это сообщение автора поблагодарили: gl00mie (5).
Старый 19.12.2013, 12:02   #2
зарепортил куда-то?
Старый 19.12.2013, 16:22   #3
Slava Chernenko is offline
Slava Chernenko
34 / 15 (0) ++
Ты уверен, что Саша это сообщение увидит? Это же блог-бот скопировал с его блога.
Старый 19.12.2013, 17:26   #4
Stitch_MS is offline
Stitch_MS
Аватар для Stitch_MS
397 / 483 (17) +++++++
Только что увидел .
Нет, еще никуда не репортил.
Вообще баг странный. Такое впечатление, что на моем теперешнем клиенте это работало весь последний год (CU3), и только сейчас вылезло (CU5). В моем собственном коде, так что его пришлось срочно править.
В RTM, кстати, тоже воспроизводится.
Последний раз редактировалось Stitch_MS; 19.12.2013 в 17:57.
За это сообщение автора поблагодарили: kashperuk (5).
Старый 21.01.2014, 18:58   #5
wojzeh is offline
wojzeh
Аватар для wojzeh
681 / 517 (19) +++++++
а как мне зарепортить про драгндроп?
Felix nihil admirari
Старый 19.12.2013, 14:08   #6
lvan is offline
lvan
Аватар для lvan
858 / 82 (4) ++++
а куда можно репортить, кроме как через New Support Request на PartnerSource? (для которого предоплата нужна)
Старый 19.12.2013, 14:24   #7
Сообщение от lvan Посмотреть сообщение
Ну, если у вас нет возможности зарепортить через официальный канал, то можно хоть сюда - тут когда-то была тема для багов, а добрый дядя Ваня создаст в системе (правда это будет касаться только след. релизов)
Но лучше конечно, когда через официальные каналы - хот фикс можете получить, да и вообще.
А Саша как раз имеет возможность зарепортить, вот я и спрашиваю
Старый 19.12.2013, 16:18   #8
lvan is offline
lvan
Аватар для lvan
858 / 82 (4) ++++
ну баг такой не особо критичный, но интересен тем, что в дебаггере виден код, который не виден в AOT
короче я щас проверю на демо-машине последней, чтобы вам проще было воспроизвести
Старый 03.01.2014, 12:45   #9
Создал баг, посмотрим, что скажут.
За это сообщение автора поблагодарили: Stitch_MS (3).
Старый 03.01.2014, 14:00   #10
Stitch_MS
Пардон, забыл отписаться, что тоже создал баг, и добрые индусы уже работают .
Старый 18.01.2014, 01:50   #11
Вот тебе ответ на мой баг (Won't Fix):
This is a well-know limitation due to the existing kernel implementation where only data buffer of the current table can be put in the collection list.
There are two possible work-arounds.
1. use xRecord.buf2con() and con2buf() to pack/unpack all the data buffers in the inheritance chain as container put it in the container.
2. use a class that holds the reference to the table variable, and put the class instance in the collection list.
За это сообщение автора поблагодарили: Stitch_MS (5).
Старый 15.02.2017, 16:53   #12
Logger is offline
3,996 / 3293 (117) ++++++++++
Кстати, упаковка таким способом
con = [buffer];
buffer = conPeek(con, 1);
[buffer] = con;
Также имеет упомянутые проблемы. Поэтому кучу старого кода при переводе на 12-ю надо перепроверять.
Касательно использования листов и мапов мой коллега еще одну интересную особенность нашел:
Если у нас есть буфер в котором есть куча длинных строковых полей (например, текстовые поля по 250-1000 символов), в которых значение пустое или записана короткая строка, то буфер в памяти занимает все запланированное место. Т.е. поле имеет длину 1000 символов, там хранится строка из 10 символов, то памяти под хранение все равно отведено 1000 символов. И это же верно при сохранении буфера в map. Поэтому если в мапах кешируем много записей у которых куча строковых полей, то они могут сожрать неожиданно много памяти.
Чтобы такого не происходило, можно в мапе хранить контейнеры в которых упакованы буферы. Память существенно экономится. (Все это проверено на 2009-й аксапте. В 2012-й не перепроверяли)
Последний раз редактировалось Logger; 15.02.2017 в 16:58.
buf2con, con2buf
Часовой пояс GMT +3, время: 11:29.
