Старый 22.08.2011, 17:11   #1
palleagermark: Working with files that are supplied by or generated for clients
Источник: http://palleagermark.blogspot.com/20...pplied-by.html
When you have jobs that require clients to upload a file to AX, or you have a job requiring AX to create a file for client, you earlier had to place the file in a folder with an UNC path available to both the client and the server.
In AX 2012 you can use the class SysFileStoreManager to move the file between server and client, so the client doesn’t need to know about or deal with UNC paths.
More information is available on MSDN: http://msdn.microsoft.com/en-us/libr...remanager.aspx
Gareth Tucker: Installing the Customer Care Accelerator (CCA) for CRM 2011 Blog bot Dynamics CRM: Blogs 3 23.12.2011 09:16
emeadaxsupport: How to manually deploy ODC Files to Microsoft Dynamics AX 2009 Enterprise Portal Blog bot DAX Blogs 0 17.02.2010 21:07
Muhammad Ali Khan: Using Business Connectivity Services(BCS) In SharePoint 2010 For Connecting To MS CRM 4.0 Blog bot Dynamics CRM: Blogs 0 25.01.2010 01:08
dax-lessons: Generate XML Documentation Files for a project - DAX 2009 Blog bot DAX Blogs 0 04.05.2009 14:05
dax-lessons: Generate XML Documentation Files for a project - DAX 2009 Blog bot DAX Blogs 0 08.08.2008 19:06
Часовой пояс GMT +3, время: 21:20.
